havols
Well-Known Member
Hi AK members
I write from Brazil.
I am working on rebuilt my personal use unit, a SCOTT 210-E
It is in Near mint condition, with metal-leather case, and all original tubes... Including 2 Amperex EL34.
Well. Until now, i just replaced:
Main cap filter Cap (40+20+20 X 475V) by 3 axial 47uf, 22uf, 22uf X 500V
2 coupling caps 47nf by 2 new one orange drops 47nf X 600V.
So, after this, i power on the amp with dim bulb test (40W) and 122VAC on the wall.
The 210-E power on, but the bulb test light a bit strong. Maybe the bulb lamp should be 100 Watts, not 40 Watts.
After this, i power on it direct on the wall, with 122VAC.
The amp power on normally, playing music, with some noise. The B+ is very high, like 780DCV. So, i turned off the amp quickly.
I can't find Scott 210E schematic, just find the SCOTT 210D schematic. But I think is similar.
If anyone can help me, to fix and adjust this SCOTT 210-E, i will appreciate it.
I use it in AUX/ TUNER/ TV and Mag Phono inputs
For while, i will replace all the others electrolytic caps.
regards from Brazil
regards from Brazil
