Scott woofer manufacturer
Heppner
If you remove a woofer from the baffle, you will probably find an EIA/date code on the back of the mounting rim that will verify the manufacturer.
Heppner ID code is 575, there will be 3 more digits that follow, they're the date code.
Heppner
Thanks! I'll confirm the EIA/date code this week.
You may or may not find something like this:
Nice save - - - this looks like some really excellent raw material to work with. Are those 15" woofers? The mid with whizzer cone looks like a Phillips with the octagonal basket frame, and the tweeter looks almost like the dual tweets found in the AR-2 (see pics).
Heppner
Heppner would be my guess too. Yellow printing on a matte-black painted frame is pretty much a dead giveaway.
Regards,
Gordon.
Removing the 15" woofers from the baffle proved challenging, as the woofer is screwed to the baffle and sealed with putty. So, I left them on the baffle. I did find the attached code on the woofer. Any ideas on the code? Thanks for the prior responses, as well!
That's a code for the cone itself most likely, which is neither here nor there but I thought it was worth mentioning.
338 is the EIA code for Daystrom, which owned Heathkit, but I'm not sure Daystrom actually made any speakers or parts. :idea: So that may be just a coincidence.
