That is true in a perfect transformer, but once a load is connected to the secondary of a real transformer, losses increase through the transformer producing phase shift and response changes relative to the primary winding, that can increase significantly as delivered power is increased through the transformer. The best transformers minimize these losses, but even in the best transformers, the losses will still occur to some degree. In a true global NFB design, the transformer must be very effectively coupled internally to prevent upsetting loop stability under all operating conditions, while in a non-global design, the there is little concern for the transformer’s changing transfer characteristics under changing power and load conditions. Such designs therefore invariably do not use or require transformers of the caliber that global designs typically demand.
Dave
Dave
