Clinton23
Hello. I’m new here.
I’ve had my SL-1500MK2 for 30 years and it’s like a friend. I’ve done some basic maintenance over the years: soldered in a new set of RCA cables for example. But the current issue is beyond me.
When playing at 33rpm the pitch slips high momentarily, in a cyclic manner. I can correct it manually by letting it come up to speed slowly with my finger. I’ve taken it completely apart. Inspected every switch, transistor, wired connection etc. I cleaned it all with contact cleaner and lubed the moving parts of the motor. I don’t see any visible issues. But the nature of the issue seems physical/mechanical by the rhythmic nature of the symptom.
I understand that the controls are digital. What’s the likelihood I’m looking at a bad circuit board here? All the digital displays are working and the buttons send the correct commands: start, stop, 33, 45, pitch up and down.
Thanks for your input.
Clinton
It’s doing it in the 45 setting as well now. It speeds up and drops down to correct pitch over and over. I can correct it by dragging the platter with my finger, holding it steady at proper pitch for a moment, then letting off finger slowly. Which again seems like a physical/mechanical issue, but I don’t know. Your advice is very welcome.
