I just picked up a Legacy Audio High Current amplifier (an early one with no serial #, made by Coda as far as I can tell) with the intention of driving my SDA 3.1TLs with it. I am currently using an NAD 2200.
However, looking at the Legacy published specs (from the paper manual that came with it, as I can't find the specs online - 220 watts into 8 ohms, something like 350 into 4, with 50 amps of current) versus the NAD's dyno specs I've found (see below, 230 watts into 8 ohms, 340 into 4, but almost 1000 watts of burst into 2 ohms), I'm not sure it'd actually be an upgrade.
The Legacy Audio (Coda) (Edit: not cap coupled!) power light stays on for a minute or so after I turn it off (only did a small test on my kitchen table to make sure it works).
Edit: I suppose it's worth mentioning that the Legacy / Coda is class A for the first 10 or so watts versus the NAD 2200 purely A/B.
Anyway - would love any input here. Will probably swap in the Legacy Audio amp tonight and see what happens but any more educated / experienced insight is always appreciated.
Thanks,
Ryan
(And yes, the Legacy Audio amp is common ground.)
The NAD's amp dyno results (screen cap'd from YouTube, check them out, credit where credit's due!)
And the Legacy Audio undressed
Thanks,
Ryan
