exwhyzed
Hi All,
I'm looking for suggestions of Op-Amp based preamplifiers, where changing the Op-Amp will change the sound.
Since many of you have, at a minimum, worked on your own preamplifiers, you have the first hand knowledge that i'm looking for.
I'm in no rush now, but at some point in the future, as I come across deals here and there, i plan to get a budget (even BPC) preamplifier and "roll" the Op-Amps to experiment with the output sound. I had success with this on my power amp and now want to try rolling with a preamp. I currently have a Yamaha C70, and while it does have Op-Amps inside, I don't believe they are used to process the sound directly (expect for the headphone Op-Amp).
I look forward to your suggestions!
