mjw21a
Ok so I recently acquired an EAR 834P copy from Douk Audio and have since decided that the Yaqin MS23b simply isn’t going to cut it in my secondary system any longer I need another EAR copy.
The interesting thing is that with the EAR 834P copy my cartridge ranking has completely changed. My Denon DL303 has better detail and resolution than my DL103 and seems to have gained body which it previously lacked. On the other hand it seems a pain in the neck to get VTA adjustments right on and it changes dependent on whether it’s a 180g vinyl or thinner.
My Grado Reference Platinum 1 performance has improved slightly from with the Yaqin MS23B which is nice, the only issue is that the performance of all my other (less expensive) carts have improved to the point that they’re on par with it or surpass it in some areas.
Of particular note the Empire 4000 D/I has detail and resolution on part with my Denon DL303 (they do both have shibata tips) though lacks a little of the magic of my DL103. It does seem a bit warmer and more neutral than the DL103 though. It’s certainly more detailed and neutral than my recently acquired Grado Reference Platinum 1 as well which seems to give a better sense of space and surroundings though at the expense of the music production itself. Yes, it’s a nice cart, though its just not as good as the Empire cart which is frankly second only to my Denon DL103.
Now I’m currently trying all of these on my JVC QL7 while I wait for the Fidelity Research FR-24 II tonearm for my new Ariston RD110 SL turntable so I guess I’ll need to try them all voer again. I’m thinking that if this remains true with that table then I should sell up my Grado Reference Platinum 1 with Microtracer tip and Denon DL303 with shibata tip. The DL303 also needs a quality SUT to get the ebst out of it. I’ve only 1x Jensen Copper Foil type SUT whereas my backup is an Ortofon T5 SUT. Nice though not really on the same level. The Empire cart is simply the better value offering here and less fussy about setup. User replaceable styli is a nice plus too.
Anyways, you opinions would be appreciated here.
