I posted something similar over at the Lansing Heritage forums, but getting radio Silence.
I Currently have a few pair of JBLs left, L7s, XPL200As, and L300s. The L300s have been modded as I have charge coupled Nelson Pass crossovers in them (still have the originals sitting on a shelf). I don’t need to sell any of them, but with the L300s being the biggest and my DIY plans being big figured it was best to move them. Plus with my wife and I just having twin girls that are now 6 months old, they’ll buy a pack or two of diapers and formula.
So, onto the DIY plans. This will be for my home theater so I will be making 3, the center will be turned when I listen to music in the basement.
For the bottom end I’ll go 18” and I have 3 NIB 2242hs and 3 gently used 2245hs. I can’t decide, I’m leaning to the 2242s, I would love others’ input though! Why I’m thinking 2242 is because I’ll have them full range for music and crossed at about 40 hz for movies to some Dayton Ultimax 18s. So not too much demanded from them.
For midbass each speaker will get two 251Js. Similar to the 2251 except that these have bigger neo magnets, bigger heat sinking, bigger coils, added mass, aquaplas coating, and I believe copper shorting rings. From what I know these drivers were only used in the SK2-3300.
The midbass will cross to a 435Be, which is a 3” beryllium that has been coated in aquaplas. They’ll be mounted to the H9800 horn.
One thing I like about these horns is that they’re notched for the super tweeter! Which brings me to the last driver, 045Be. It is a 1” beryllium and again I believe it too is coated in aquaplas, but I could be wrong about this driver.
So technically I have three SK2-3300s minus the cabinets. I’d like to add an 18” woofer to each to make a full range speaker.
Here are my thoughts on the crossovers. The original passive crossover ran one 10” from 0hz to 150hz, the second 10” from 0hz to 850hz, the 435Be from 850hz to 20khz, and the 045Be from 20khz up. All crossover points are 4th order (24db per octave).
What I was thinking of doing is running the two horns on the passive crossovers, their factory points. I’d use a DSP on the 18s and the 10s. I’d run the two 251Js up to 850hz and down to 200-300hz where they would meet the 18s. So I’d run the 2242Hs to somewhere between 200-300hz. Again, would absolutely LOVE suggestion on this or critique.
So figure they would look like this:
With this on top lol
Or potentially this, which I’m not completely digging yet.
As for DSP I can’t seem to get much as far as suggestions so for now I’m settled on picking up 3 minidsp 2x4HDs, but if there is something you think is better out there please let me know. Figure without subs I’d need 9 channels of DSP. Even though I’ll have the two horns running through the passive (glad they’ll have the passive as protection as the replacement diaphragms are insane, nearly 1k for each of the 3”) I’d still like to run those on a channel of DSP so I can play with timing and such.
Anyways, tell me I’m stupid to sell the L300s, or that you’d do the same, tell me whatever you want, but I feel I really need input from others.
Thank you so much!
Dan
Thank you so much!
Dan
