Sennheiser HD-424s Component Upgrades V2
cscottrun4it
I'm cross posting this from the Headphones forum, where it's had 1 response. I'm hoping someone can help me with these questions...
I finally got my HD-424s. I think they must be relatively unused, as they've had quite a burn in period - going on about 40 hrs at this point, and they keep getting better. The bass is becoming much more responsive and showing signs of actually getting somewhere close to the 16Hz advertised. (I know - I can't hear 16Hz, but bass shouldn't be lacking with that spec.) Also, the near ear-splitting treble is being tamed. I can listen at volumes approaching fun without fear of never hearing above 10000 Hz again.
Nonetheless, the HD-424s are unforgiving of poor recordings, at least so far. They are great with HiRes audio, CDs, and well preserved/recorded vinyl. But them "stereo" Beatles albums? For get it. My snap, crackle, and pop Kinks albums from Goodwill? No goodwill shown there, either. Physical Graffiti? Well, the original pressing of that album sounds like badger scat on anything, but particularly on the HD-424s.
Oddly enough, for headphones that were for sold between 1972 and 1976, they like modern recordings far better than recordings from their day. (The drivers on my HD-424s are metal backed. I read those were made until 1976?) So, I've been asking myself, how good are the cables on the HD-424s? Would different cables open things up and make them a little more forgiving?
Before you answer, let me remind everyone of the HD-424s' specs.
2000 Ohms resistance
94db at 1mW
Getting to 1mW at that resistence has been tricky. None of my sub $200 headphone amps will do it. The guys at Shiit said none of their amps would get there. So I've turned to one of my speaker amps. Plus, that resistence scares me, as I know nothing about cables and 2000 Ohms. And there's the ability to easily change the cords themselves.
So the questions are...
  1. It looks like I should be able to pull out the connector ends on the driver side of the cable just like you would with the Sennheiser HD-600s. Anyone know if that's true? I'd hate to break these things. The cable seems pretty well affixed to the drivers.
  2. NOS cables for the HD-424s are out there on the internet. Their connectors look very similar to the modern Sennheiser headphones. I can't quite tell if the plugs are two different sizes, however, like the modern cables. Anyone know?
  3. Let's say all of that lines up, what do I need to know about cables and the resistence on the HD-424s? I've been considering this cable, at 10 ft, with the 1/4" Furutech FP-704 plug:
https://www.etsy.com/listing/576188778/sennheiser-hd25-1-hd525-hd535-hd540.
Or... maybe changing out the cable to one that uses modern wiring and couplings is a fool's errand? Normally, for $80 headphones, I'd say yes, but $80 in 1976 is $500 in today's money. I would certainly play with the cables on $500 headphones.
I'd hazard a guess that changing the cable would only have minimal impact. That 2000 Ohm spec is a killer. Changing cables really won't help that, it's probably the drivers where that lives.
EQ may be your best friend here once the HD-424s stabilizes.
Mark Gosdin
