Some comparisons,
I've not had a Pioneer receiver for years except a suspect SX780. I say "suspect" because it puts out an awful lot of bass..and flipping the loudness off and on makes no apparent audible difference..nor does it kick the meters up to any higher output as it should if the loudness circuit is working! I believe it is stuck.."on".
I have had however, a Pioneer SA7700, SA9500ll, a Spec1 & Spec4, and finally a Spec1 & Spec2 pre- poweramp setup all hooked to the same set of a/d/s speakers for the last 15yrs.
All these amps sounded much more alike than different..and much different than the 'suspect' SX780.
The little 7700 integrated was also rated at 60 watts, the same as the receiver, I believe..it's been a while. Anyhow, it was much higher on the clear, clean, well defined, balanced and Oh yeah that's Nice sound factors than the receiver even thinks about being. No doubt.
As for the 9500ll...it was hard to tell the difference from the Spec1/4 system. An 80 watt integrated with dual mono design..seperate transformers etc..it sounded nearly identical to the Spec setup..nearly. The Spec's did have more definition, bass and soundstage, but not by much. As far as my memory goes anyway, and memory can be a funny thing
Now the Spec 2..at 250watts a side, that's a different story!! The sound just leaps out of the speakers, with definition and presence. At any volume. Bass with "air" around the instrument..soundstaging beyond anything I've ever owned..or heard besides a McIntosh setup.
The integrateds had about the same kind of qualities..and all of the amps are clear and clean..but the Spec 2 is clearly in a class by itself here.
