Series would help circumvent the user from connecting two pair of 4ohm speakers being seen by the amp as 2ohm and having a melt down. Other than this I don't see any reason either. This method is often used in the automotive sound industry connecting multiple subs.I don't see any reason to connect speakers in series. It is parallel as gadget73 explained.
It should be easier for an amp to run a 16 ohm load than a 4 ohm load.I don't see any reason to connect speakers in series. It is parallel as gadget73 explained.
Makes sense. Thanks!!push the A+B switch and see if both are live with only one set hooked up. If both are active with one speaker connected, its parallel. If both need to be hooked up, its series.
I'd all but guarantee its parallel though.
I have heard that vintage home audio amps did it both ways.
Is this speculation on your part or have you tried it? This is common in car audio and pro audio.Cause the first speaker will suck all the sound out of the cable, starving the second of any output at all?
In my amplifier collection is a Toshiba sc-665.
I can hook up two pairs of speakers and select a+b if I choose to do so.
How do I easily determine if the amp puts one pair of speakers in series with the other or parallel with the other?
So 1 amp per speaker pair is better the way to go.
No way around it.
Yes, one stereo amp per pair of speakers, one channel per speaker.One speaker per channel.
Are you sure, or might there be another reason?Amps that put speakers in series mean that the power supply is light weight.
