I have a pair of KLH 20 speakers that I am about to restore. I am not going to wire in binding posts. I want to use them in a stack with a mono Dynaco Mk III, so I have to connect them in series to get 8 ohm. My question is: If I connect the 8 ohm connector from the amp to the (+) wire on RCA one, then connect the (-) wire from RCA one to the (+) wire on RCA two, then connect the common connector from the amp to the (-) on jack two, will this give me a series 8 ohm load? Does this make sense?
Thanks!
Thanks!
