Yes, fade in and fade out are working properly.Hi
I am not home but is the fading function working properly ?
And how long is the fading time ?
Maybe the indicator is blinking because the duration is set to minimum/maximum.
Correct, changing the fade duration (fade in or fade out) has no impact on the light blinking.Have you tried to modify the duration of fade in/out ?
Any help locating the XTEST test point would be appreciated. I will dig the unit out of my stack tonight and see what I can find. Never done this before.Could you locate the XTEST test point on the main board and check the continuity with ground ? (Power off)
Hi, I replaced that cap on my earlier 59ES, but on this one not yet (but I'll replace it anyway).Check power supply outputs.
Did you replace C907 ? (6800 µF / 25V)
The 10V DC is non regulated, so I guess that 0,3V AC ripple is no problem.
The 6800µV cap "supports" around 12V, so 25V is more that enough. If you have caps with higher values, no problem.
If the guides retract with caution mode, there should be a problem with the heads. Do they rotate ?
Hello.Hi guys,
My DTC-55ES suddenly developed a strange fault in that the pinch roller will engage and touch the capstan axis in FF or REW just like in PLAY MODE, making rewinding or fforwarding very slow (Same issue in track search).
Everything else works as it should, the mechanism is aligned by the book so I cannot see why this is happening.
Any ideas as to what might be causing this odd behavior?
Any advice would be highly appreciated, thank you in advance!
Thank you @hdrobienHi
Could it be a slightly misaligned rotary encoder ? (considering its inner contacts are clean).
From my experience, the best setting is not when the pinchroller is "surfacing" the capstan housing when seen from above in standby mode (according to the service manual), but a little further away.
