How long does it take to travel 2cm ?My problem is all three of these arms only travel about 2 centimeters at a time and then stop with the caution message then displaying.
Hi. If the threading rings, arms and gears have been cleaned and carefully regreased and the belt is good it only depends on timing:
I assume the threading rings are aligned by putting a thin screwdriver through both of them and the hole in the chassis below that position? Good. Then put in the gears and assemble the rest.
No turn the beast around and spin the pulleys with the belt that drive the loading mecha and ensure both loading guides move towards the head drum and reach their stoppers about same time. On the last portion of that movement the pinch roller arm starts to move towards the capstan.
If all move freely and in sync move the mech until the pinch roller reaches the top bearing tower of the capstan - not the capstan itself and 1mm to capstan is way too close.
The top of the capstan housing that is farest from the capstan and the outer end of the pinch roller's rubber need to be aligned.
At that position the rotary encoder needs to be assembled in its mid position with the mark and line aligned.
Then power up and the threading arms move down. Insert a tape and check. Fine tuning can be done by turning the rotary encoder in its long holes.
I believe that there is a timing check to prevent damages if the loading / unloading sequence takes too long. The DTC-55ES has such a feature.
