Might re-read my previous post. When you suggested that I said to use a 27V 1W zener, I wasn't sure what you were talking about. Your new post here bumped the thread up, and now I see it. I've posted a mea culpa edit.
Filter capacitor removal and Relay / Rectifier board access.
I first disconnected the wiring from the bottom of each of the large filter caps. Then, I placed the amp atop two large books, each about three inches tall, carefully spaced such that the books are at the far ends avoiding any jacks or terminals on the back of the amp. Next, I sprayed soapy water around where the cap and bracket meet serving as a lubricant. I then gently wiggled at the two filter caps until they had become loose enough to take out by hand. With these capacitors out, it opens up easy access to the top half of the clamp and its mounting screws (shown already removed in Photo 1 below). The bottom half of the clamp was still nestled behind the transformer. To access these screws, I needed to remove it from the chassis. The transformer was held in place by four 8mm hex nuts on the reverse side which I removed with a socket wrench. Before pulling the transformer free I placed a rag beneath it to avoid any damage and freed up the wires at the back to provide a bit of slack. With the transformer off the chassis it can be maneuvered around a bit to reach to the two remaining screws left holding the clamp.(see Photo 2 below)
The second transformer is removed in the same way as the first. Access to the top screws was straight forward through the gaps to the inside of each of the rectifier heat sinks. (See Photo 3) The screws behind this transformer were a bit more challenging to reach. The capacitors are left in the way, but with a little patience and maneuvering of the transformer an opening for the screwdriver shaft presented itself. Once the clamp was freed from the chassis, getting the caps/clamp out required me to take the two screws from the relay/regulator mount out. With the screws removed, I was able push the circuit board upward slightly which provided some much needed space for the clamp/caps to slide left and then out.
With the filter caps removed and the transformers re-attached to the chassis, the amp can now be placed bottom down. The relay/rectifier board is now accessible for solder work to remove and replace the old relay. (Photo 4)
Photo 1: The Kenwood 500 atop two books backside down.
Photo 2 : Accessing the mounting screws of the filter cap clamp shown behind the transformer.
Photo 3: Removing the second transformer with the caps still in place.
Photo 4: With the filter capacitors removed the solder side of the relay/rectifier board is accessible.
Right Channel Power Amp (X07-1440-00)
Every transistor on the right channel power amp board, with the exception of the Dual FET, was evaluated. None of them test shorted. All of the resistors were checked for value in circuit and only a couple of them weren't close to the rated value. Those two were pulled and they checked out fine.
I suspect either one of the the two 2SA810 (Qe3,Qe4) or the 2SC1452 (Qe6) were going bad though, as these are known to fail. They were replaced with KSA1381 and KSC3503 respectively. I also replaced 2SA673A (Qe7, Qe10) with KSA733C and 2SC1213A (Qe8,Qe9) with KSC945C. The heat sink mounted Qe11,Qe12 were given fresh compound.
Though they tested fine, I figured I'd replace the zener diodes while I was in there. For De1 EQA01-24 24V 500mA, I used a 1N5252B. For De2 YZ-140 14V 500mA, replaced with a 1N5244B.
R14 looked pretty shabby (see the before photo), so it was replaced with Vishay/Dale 1K metal film. Having looked at photos of other Model500/600 amp boards and also the parts list in the service manual, my board is the only one one I've seen use a 1K resistor in that position. The others all had a 100Ohm part. I verified that the left channel had a 1K installed also.
An orange low leak Elna CERB 10uf 25v capacitor is checked. Notice the ESR measures pretty poorly when compared with say a Nichicon PW of the same size and value which likely has an ESR half that. This is not an anomaly, all of the 10uf orange Elna low leak caps measure this way and seems to indicate the leakage current was of more importance to the engineers than the ESR.
One of the special features of the Model 500/600 Supreme amplfier is this Sony 2SK58 dual FET which is enclosed in this small, shielded metal case due its temperature sensitivity.
Here is the finished right power amp. I've squeezed three Wima 10uf 50v polyester caps in place of the 10uf 25v Elna CEBR caps at Ce5-8 and an Elna Silmic II 10uf 50 at Ce5. Each of the Vr trimmers were replaced with 3386H Bourns single turn. Vr1 and Vr2 got 500ohm, and Vr3 a 50K. Vr1 is the coarse adjust and Vr3 the fine adjust for the offset metered at pin 13 and set as close to 0mV as possible. Vr2 is the bias adjust set to 25mV while metered across pins 5 and 6.
After a partial reassembly and the 4 Sanken outputs reinstalled I fired the 500 back up under full power. I set the offset and bias per the service manual and then shut down long enough to hook up a CD source to Aux 1 and have a listen through the headphones. The right channel distortion is GONE, just a nice clean signal now. As I said before, I can only speculate that I had a failing transistor at Qe3,Qe4 or Qe6 as all parts tested okay. A bit anti-climatic in finding the guilty part, but you can't complain with the end result.
With the repair completed it's time to move on to the restoration.
