I have a decent level of knowledge on restoring old tube equipment. But SS brain cells are a bit dated, hence the question here.
The Service Manual has an elaborate setup with a distortion analyzer, which I do not have. The second method utilizing a watt meter on the AC line, I have on with a 0.1 resolution. No idea how accurate that in setting bias, but sounds a bit wonky to me. How much of a shift in AC power will indicate you have hit the correct setting? Is it a cliff/vertical rise that you will see?
I do have a good scope, Voltmeter, and signal source.
A question that was posed earlier but not answered. Can you use voltage across the emitter resistors on the output transistors as a guide? If so, what voltage would indicate a correct bias?
Or, is there a generic way to set bias on thise types of output configuration?
Thanks in advance.
Thanks in advance.
