HI, I am setting up several of my various amps/preamps/ cdp/dacs on a commercial steel wire rack in my basement . The rack is pretty much what you might see in a hardware store or convenience store, 1"steel tube verticals with 5 adjustable wire shelves. It is about 8 feet tall, has adjustable threaded feet and makes for an approximate 2x4' foot print . I have already cut floor underlayment to place on each shelf for the equipment to rest on.
The basement floor is poured concrete and the basement is heated in the winter, and remains a pleasant 58-60 degrees during the summer, my wonderful spouse has no concerns about how it looks, she has agreed the basement is my real estate to do with as I wish .
As I get the rack in place, I am wondering if there are any "tricks " I should know about before I start setting everything up. Should I place the legs in sand buckets to isolate vibration or is that moot on a concrete floor? Should I stiffen the rack as much as possible ? Other suggestions? Air flow should not be a problem, the rack will have open space all the way around it and shelves will be about 18 inches apart.
Thanks in advance!
Thanks in advance!
