FrankFIII
The Sharp RP-117 TT has been working fine all summer. After a short time of non-use due to trying to prepare for winter, I went to use it again to play some Christmas albums. While it did play, initially, I thought I had not pressed the both sides button or pressed the repeat button. So I dismissed that as operator error and tried again. This time I was watching it and the TT simply reset itself and went to a state as if I just put an album in but did not press play. I tried again with another album and it worked perfectly so I thought is was just a fluke or operator error by me fat fingering something. I tried to run it again yesterday. This time it happened again. The unit reset itself and went back to the home position on side A. I also noticed this only happens while it is warming up in temperature. When it has been running for a while it seems to behave. When the event/rest does happen, the LEDs and the lamps on the from panel seem to blink out or go out briefly in a blink of an eye. When the lights comes back on, depending on the duration, I may have no LEDS or 2 LEDS on at the same time for tonearm position or it just continues on without a change. If long enough, the unit resets like a power outage. This could be tricky to track down. anyone ever see this type of behavior?
