vagabondjoe
Hi
I found a Sherwood Micro CPU 100 Tuner and from reading the manual that I found online. it seems I need an amplifier.
When I first hooked it up, I foolishly connected the speakers to the Variable Output, and received a weak output volume.
I also have a Sansui RG-707 Graphic Equalizer Consolette; the connections are
(here is a graph, the Os are the connections)
Line
Source In Mixing Out
Left O O
Rght O O
Question - Can I connect the Sherwood from the Variable Output to the Sansui Source In, and the Speakers to the Mixing Out?
Or can you suggest an inexpensive amplifier?
thanks
If this doesn't work, I don't know to do with either of 'em.
Line
Left O O
Rght O O
thanks
