mhardy6647
Lunatic Member
oops. Thanks Tom (he said sheepishly).
The voltage at the rectifier should be -30 to -33V. If so it's fine as-is. A resistor in series with the preamp tube heaters will bring them back into range if it's higher. Three 150 mA tubes: 12.6 +12.6 + 6.3 = 31.5V, so if you see let's say -36V, you want to drop about 4.5V at 150 mA or about 30 Ohms, 2W.
Having bias voltage greater than the nominal -30 is not necessarily a bad thing - it will reduce the idle current and the output tubes will run cooler.
Sorry for the apprentice question, but where exactly would I put the probes to test this voltage? It has been a long time since I studied electronics in high school!!
Easy to find if you don't mind the Russian tubes (which work well and sound good).
A pair of silicon diodes (1N4007 or UF4007 or similar) will replace it - if you get more than 30V for bias, it might be a good idea to add a resistor in the preamp heater string to keep it to 30V. But this amp pushes EL84s pretty hard (452v!). I'd use EL84M - Russian 6P14EB - which are rated for this high voltage. Jim McShane has them.
Schematic is on my page: http://www.audiophool.cjb.net/hifistuff.html
I am surprised that the schematic does not call out for 7189 tubes instead of the standard 6BQ5/EL84. Were the EL84s in that era a more rugged tube?
Which one of those many links shows the diodes?
