marantzgrail
Good morning my fellow Audioholics!
I picked up a Sherwood ST-802 simply for the cartridge it was being used with. Now I've turned my attention to getting these TT's, receivers, etc to become usable once again.
My issue with the ST-802 is that when set on either 45rpm or 33rpm the table will speed up then slow right down over and over, should I just let it play for a few hours and see if it will work itself out or what do you think I should do? I must mention that the TT has a variable speed dial to tune in just the right rpm.
Do I open it up and clean the variable speed controllers with some Deoxit Gold as well as all the other electronics? What would you use to lubricate the servo and gears.
Lastly does anyone have a service or user manual for this particular TT?
Thanks very kindly!
Thanks very kindly!
