Nigel Hall
2nd image shows my DIY horn-on-a-base of MDF which has the cover parts at the rear..
I totally get where you are coming from re the manufacturer, but if the compensator works then you only need (buy or) use what you may already have in parts for them..
BTW, for my setup I needed to drop the value of the horn cap & drop the attenuating resistor to 1 ohm..
