So, for those not familiar with all or any of this stuff, the 300B amp is a delightful piece of audio royalty. These amps are usually confined to serious listening environments....and coupled to exotic speakers and source material. The result is predictably consistent and generally VERY impressive. The amp here was right in the pack with the rest, and built by it's owner some 8 years ago (or so I was told)! The speakers....the Cain & Cain Abby speakers....... 'Amazing'!! 5" Fostex drivers in a proprietary cabinet that stands about 6' tall.....a 'wedge' shape, drivers placed about center of the cabinet, and a tuned port at the lower section. I'd never seen them before...but now I want a set. The DG-SE1? A modest amp built with $15 output transformers, a pair of EL84 output tubes, also Single Ended, and about 3 watts. Most significantly; Designed by Mr. David Gillespie! (built by yours truly). Source material was through some esoteric 'streaming' device I won't even pretend to understand.
So, the point of this exercise was really two-fold: 1) to compare the two amps, and 2) for me to spend a bit of time listening to my little DG-SE1 on a pair of smaller speaker of the full-range type. So, to start this, I got to listen to the 300B for a bit while drinking a gucci beer! Then, the real test: Could the humble little DG-SE1 even HOPE to keep up with the 'class' of the audio industry.....and produce any kind of sonic reproduction that would even let it last more than a few minutes! Well.......Surprise!!! The first cut of a female vocalist, accompanied by a Sax player.....AMAZING!!! I think we were both in shock. Next cut....some fancy piano work..... or so I recall. I think I was still reeling from the reality that this little amp was not only producing incredible sound, but the speakers were only 5" on each side....and the sound was simply breath-taking!! On to some Larry Carlton....then we finished up with a simply stellar cello piece. The 'depth' of this last piece was enough to leave you speechless when it was over! And, the best part: The owner and builder of the 300B simply couldn't believe the little EL84 amp was producing sound like that of his 300B.....with only about $100 investment in parts....and built between 9:30 am and 10 pm yesterday. Yes, the DG-SE1 was only 24 hours old.....and already earning a reputation as a 'ball-buster'!!
I'm attaching a couple of pics....wish I took some more. But, hopefully this will validate some of my claim. This was a GREAT evening!!
Tom D.
Tom D.
