Jesse14
Polling the hive in hopes I can finally resolve this: I have a fully professionally restored Harman Kardon 730 that looks and sounds gorgeous. I use it mostly for vinyl, for which I use a Realistic Lab 400 which was professionally serviced prior to adding to my setup. The issue is that - frequently - my right speaker shorts out (?) during playback. The R400 has hardwired RCA's but I don't believe those are the problem (and I have switched pos/neg inputs and the problem is consistent with the right speaker). When this happens, it seems the only thing I can do is fiddle with the turntable ground wire at the receiver ground knob. I always have the exposed wire-end snugly turned around the ground pole with the knob securely tightened. When the speaker shorts, I usually have to pull the ground wire from the ground pole on the receiver. As soon as I break the ground circuit, the right speaker pops back on - but always (and obviously) with ground hum. Then I halfway re-attach the ground wire to the post and the stereo image returns for a period of time before inevitably shorting (?) out again, and I must start over. This problem has been consistent across 3 sets of different speakers. I am honestly at my wit's end with this, and my hunch is the fix is probably something pretty basic. Any thoughts or suggestions would be welcome!
