Looks like level balance isn't possible any more with the replacement knob on that Nak(amichi)? It's supposed to be like this:
If the Nak is good I'd go for that (but probably not in the state of the one you shared..) because:
+ You can plug bananas into it
+ It has more extensive I/O
+ Better signal to noise ratio
+ Is rated at 75 watts per channel. (the 217 30wpc and the other one 15wpc, all at 8Ω into stereo)
+ It has a remote
The only reason to swing it back towards the AU-217 for me would if it has a MUCH better phono stage, but can't quickly find info about that and can't honestly assume that that will be the case.
P.s. the 'Stasis' techology (or rather the topology of its design) has a connection to legendary designer Nelson Pass, which is just too cool.
Unfortunately however... He wasn't actually involved in the design of the Nakamichi's that have Stasis printed on them as he confirms himself here:
Hallo, I read somewhere that the stasis serie of Nakamichi were designed by Nelson himself... Is it completly true? I'm asking that, because I need a new tuner and I've found the following item on internet and from "next door" sellers: Kenwood KT-400 (but no-one knows anything abpout this model)...
www.diyaudio.com
P.p.s I looked into this amp for myself a while back.
