Show me your dummy load(s)!
The OP didn't mention what type of dummy load they were talking about in the topic!
Next we need to add power supply/battery pack tester dummy loads too :D (Note: PSU/battery pack dummy loads are electronically complicated (to deal with fixed voltages) versus RF dummy loads are physically complicated (to reduce inductance.))
Dummy loads for the giga-hertz crowd ECM radar jamming... Band 2, 2.5 and 3
^^ Exactly the kind of physical dimensions needed to ensure that microwaves get fully trapped and dissipated within the cavity...
And for the power supply...
And this is a homemade (simple... but do realize the complexity of what's inside the IC) ~250mA constant current dummy load - as long as the voltage is within range and the IC can handle it, a constant, approximately 250mA will flow from red to black.
Okay, I lied somewhat.
It was meant to be a constant current limiter for illumination LEDs, though the LED can be omitted and all of the power gets dissipated in the jig...
Ahhh, yes. An "Active Load". Built a few of those for a former employer, but they were a bit bigger than yours. They could safely dissipate about 10kW....
It was back in '80 I was working with active loads that were plumbed for cooling water. Used to think of them as water heaters... I don't remember the max loads. But they were for electric vehicle battery testing.
I have several sets of Dale 8 ohm 250 watt resistors. I intend to mount them on a heat sink.
We had a water cooled dummy load/calorimeter rated for 100kW continuous at Fermilab that we used for testing the RF power amps in the Booster and Main Accelerators.
