Show us your Technics stuff
New addition - a SU-V6. I had a V10 briefly but it had faults that I couldnt diagnose. These designs are riddled with unobtainium small-signal FETs on the input stages. Thats what makes them so special I suppose. This design is a lot less complicated than the V10 and all inputs are working properly! (ie: there are complementary-pair FETs on the input stages of the MC input). She is coated in dust and note the wackey bridge "repair" jobs.....this is a work in progress. Next step is a total recap and Im also painting the lid (was rusty).
Just removed the motor/ spindle bearing assembly from my SL-1500 for a rebuild, thought I'd share. I love how serviceable most Technics 'decks are, just 5 screws and you can pull the motor out, no need to remove the bottom cover.
Nice! If course this is only as easy with the fully manual version; the automatic and semi-automatic siblings require a bit more disassembly. I agree though that all these models are quite serviceable.
I dont have a pic (yet) cuz I just took it over to the store and set it out, not up yet, but I just did a SU-G90.
its not ugly for BPC and day-am, if I read it right it is 135 watts? holy buckets.
I did find that the built in cooling fan kicks on when the volume is just below 11, but! the damage inside was heat related (the -15v was partially desoldered) so I tapped the +15v to run a heat sinked 78M05 and power the fan now on startup (its a 6v fan that is whisper quiet at 5.05 v!). I recapped it, swapped out some flame-proofs, cleaned it and re-soldered every single joint big time.
SU-V6 - fully restored (altho I am still waiting on new powersupply caps to replace those also. New signal path caps with audio grade types and phono stage recapped too (this unit has an excellent MC stage).
All repainted too. Most importantly, the "new class AA" lightbulb replaced!
With those FET input stages she sounds sweet!
View attachment 839756 View attachment 839757 View attachment 839758 View attachment 839759 View attachment 839760
Hi Slimecity , Very nice amp, be interesting to hear how the recap sounds. My V8s also have some rust, must be common with that range. I tried a LME49860 and OPA1612 in my V8s. Shame about the SV-10, i picked up a NEC CD620 and had to find a service manual. Rick at StereoManuals, may have the V10 service manual
Cheers Synchro! The V10 is history actually - the circuit was so complicated I just got rid. Very hard to diagnose issues in a circuit that complicated. The closest manual I could find was for the SU-8099 but there were a few circuitry differences.
After the recap I am still waiting for the new caps to break-in a bit more to soften the sound a bit more - its happening, slowly....I was actually thinking about some op-amp swap-outs in my V6 - which op amps did you replace? I think the V6 and V8 topologies are very similar? I have an "AN 6552" in the "tone flat amp" section and an "NJM 4559 DS" as the phono equaliser.
9 MRRP $2,000.00) Technics RS-9900 cassette deck this afternoon via Ebay UK.
I've been after one all year to go in my Technics pro stack. Luckily,it's gonna be posted tomorrow,so it should be with me by the end of next week... will post a pic when it arrives.
Hello.
The really expensive 9900, was later "recycled" onto the M95 (i have the M45), a machine praised by critics because of it´s ahead-of time- technology, such as the FG direct drive motor.
Hello.
Hi Slimecity.
The V10 did look complicated, and only saw recapping repairs on a Japanese site for the V10. Awesome amp if there was a manual for it.
Nice will be interested to hear how the V6 sounds once she has broken in. I just recapped the phono eq board in my V8. SimicII, FG, and where the 3.3uf b.ps were i put wima mkp. Only opamp i changed was the phono eq one with OPA1612 and the other V8 LME49860, the LME was too bright for the V9, for the V9 i got a OPA1642, not much about this opamp but it seems good.
Technics SL 1900 purchased new in 1978 with an Audio Technica AT 13 EA from Stereo Discounters in Owings Mills Md. during a blizzard just before the store closed because of the weather..guess what I unpacked as soon as I got home. and it still works perfectly on all functions..
( bought a Pioneer SA 9500 and a pair of Sansui SPX 5500's at the same store during the same month)
Several Technics thrift store find MASH equipped 5 disc changers ...and they sound pretty wonderful for $12.00 for two plus tax.
Real good now the electronic volume controller works. It has a stack of neat features like auto eq (uses a mic to determine room acoustics) 7 band... AV / Matrix surround..
It's hi density... 31.5cm wide.... rated at 2x75w
Been using the RP-3800E
These do run quite warm indeed... I have a few of these... have a good system in the kitchen
