G'day all, once again this thread shows that everybody has their phono cartridge 'likes and dislikes', although I am rather saddened to see a discussion on early Shures (almost inevitably) degrade into a Shure M97xE bashing session. Sadly I almost expected that, all things considered. :yes:
Do we all have hearing 'flat to 20 KHz then? Not likely! When I was younger my hearing was almost that good, but not so now, although it's still pretty good to 15 KHz or so.
So when the 'real world' is taken into account I simply don't see what the complaints are. I try to get the best out of any any cartridge I have and I happen to love the sound of the Shure M97xE particularly at my favoured 62 k resistive loading. What's wrong with that? Nothing. Each to their own favoured. :yes: Regards, Felix aka catman.
Wasn't bashing.... I have it and I like it.... (well the needle in the various p-mount versions)
But objectively the design is flawed in that it depends on the mechanical resonance balancing out the electrical shoulder... (and a touch of electrical resonance filling out the midrange).
To me that seems like engineering in a series of counter balancing flaws.... with an end result that is pleasing. but....
The objectively "right" way to do it would be to get a stylus with a resonance well outside the audible range, and mate it with a body/generator/cable capacitance that has the shoulder and/or any electrical peak also outside the audible range....
So low inductance cartridge with low capacitance cable - combined with a stylus that is engineered right.
Then you are no longer using differing flaws to balance each other out - you have moved the flaws outside the hearing range....
If Jico made a N97xE SAS stylus where the resonance frequency was more like the V15V (ie out beyond 25k+) - it could be combined with a M97 body, and very low capacitance cable (100pf or lower) to get V15 like performance.
This is what I was hoping for when I purchased the N97xE SAS - but instead Jico have opted to maintain the tone and compromises made by the original Shure engineers (a valid choice too...) resulting in a needle with a very similar sound to the original. (improved in detail, and trackability, etc...)
I have tested the various bodies with the N97xE-SAS stylus - and yes it does sound great...
But for archival purposes - I was trying to achieve a flat (or as flat as possible) 20Hz-20kHz - and based on my modelling it is simply impossible with this stylus.
The almost identical V15VxMR SAS stylus on the other hand is different - it was measured by Thomas_A (published the plot in a thread on VE).
The plot shows an almost flat F/R out to 20kHz, with a small resonant peak around 14kHz.
Running the sums on his capacitance/inductance showed that the small bump coincided with the expected electrical resonance - in other words, running the same setup with much lower capacitance would result in a gradual light droop in the high end (as per the original V15VxMR F/R - balanced out in his setup by the resonant boost) but no resonance or peaks in sight within the audio range.... (ie mechanical resonance is outside the audio range)
The V15V / V15VMR suffer a lot less from the gradual HF droop - due to better core design compared to the V15VxMR (or for that matter the M series).
Take a stylus response as assumed via the above deductions for the V15VMR SAS - fit it to the V15V (or VST-V or Ultra500) with its superior core - and you have a closer approximation to a perfect MM cartridge.
This is NOT dissing the M97 and the rest of the M series - but it IS accepting and noting the limitations of the design and the compromises made by the engineers when they designed it. (I have quite a collection of the p-mount M's.... 1000e, Me75p, DT25p, M105 they are very nice...)
tmblack - I have been asking for information on the mechanical resonance of the V15VMR SAS stylus everywhere I could think of with absolutely no responses.
What I did was apply the electrical modelling maths to the plot published by Thomas_A in VE - from this I can deduce that there is no resonance within the plotted audio range.
Beyond 20kHz it also gets difficult to measure response - most test records stop at 20kHz, even running them at 45rpm only gets you up to 27kHz.
(I have managed to find a vintage Denon test disc that goes to 50kHz -so once I get hold of one I will be able to identify the resonance... I hope).
bye for now
David
