BrassTeacher
Uncurable Tweaker
I have a Siemens tube here, with almost every bit of the lettering gone, that is either a CCa, or an E88CC. Is it possible to tell which it is by the date code? Date code is (I hope this displays correctly):
Aø
1≠
5K
This date code appears stamped on a metal plate, inside the tube, attached to the getter frame. Tube has a halo getter. There is also a "4" stamped inside the glass on the bottom of the tube (where the diamond would be if it was a Telefunken), and the inner shield is grey, not shiny.
Yes, it has gold pins...
Any help identifying appreciated!
Oh, and don't EVEN try: "Ah, that's just a common piece of junk that isn't even worth using for target practice, so you should send it to me!", I'm not THAT stupid!
Aø
1≠
5K
