Signal tracer or Oscilloscope?
willne1
Member
I have acces to an Oscope but not a signal tracer. Would I be better off learning how to use a scope or should I get a signal tracer for trouble shooting an amp? I have no experience with either one so far. I do know about the dangers of working with tube gear.
Thanks
If you look around,the Heathkit IT-12 can usually be had for small money. Great little gadget,and I use mine regularly.
You wouldn't believe just how useful and how often you will use a signal tracer until you have one.
The radio fix-it guys where I used to work (decades ago) used a thing called a Huntron Tracker. Kind of a cross between a scope and a signal injector. Usually meant to be used on unpowered gear, it would display different shapes based on whether certain types of components in the circuit under test were faulty or not. Really shined when you had a working example to compare with (like a non-defective side of a stereo amp.) I think they're still around, or things like them are...
I do a lot of signal sniffing in audio land by using a little Radio Shack battery powered speaker amp and the end of an RCA jack.
The trackers are still around but can be stupidly expensive. If you can get a deal on one, they're very useful, given a certain amount of understanding and practice. IMO, they're not a beginner's tool.
