Simple Component Tester (Octopus)
Interesting. I want to build one of thse devices but there are so many different variants of the circuit. I'm wondering what you changed or added from the original circuit? How does it work for you? Thanks
Hello! It works well. I didn’t change anything from the original design.
Thanks for your reply. Your build looks nice. I have a couple other questions. Is that a rotary switch on the front for the current switch in the original circuit?
Is that a 1 Meg potentiometer or trimmer in the picture?
Was HZ65-3 was the last version made? There were some changes made to the circuit. Do you what was the value of this cap? Thanks.HZ65-3.jpg
My guess would be that "a. r." means "as required". The optimum value would seem to depend on the setting of the potentiometer as well as on the length of cable connecting to the oscilloscope.
That is assuming the capacitor compensates the effect of the cable and load (scope input) capacitance on (mainly) the phase response but maybe there is some other purpose to it that I don't see.
