Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Once I change my listening space around and tame a reflective window,I'm going to look at the source that you listed so that I can build the tube traps.Do the end caps seal well against fiberglass?Are the tubes easy to compress or damage since they don't have any solid tube under the fiberglass?
Amerisafe website sells
Knauf Earthwool™ 1000°F Pipe Insulation with ECOSE®.Can I use Earthwool instead of compressed fiberglass?How thick should the Earthwool or fiberglass be?
Hmmm. I looked at the datasheet and what bothers me is the notion that it is "molded".
The originals I have are porous fiberglass where the sound could be trapped. If this is a solid molded affair, its ability to absorb bass may be severely altered.
So does anyone know how a "solid" corner trap like this compares with just mounting an acoustic panel diagonally in a corner? Is there a big difference in absorption?
