I have recently installed an SDS labs cap board in my Dynaco PAS-3x. This board replaces the quad can cap, the selenium rectifier, and the 2000uf electrolytics under the rectifier. The board works perfectly but here's why I'm posting.
I've listened to the preamp for roughly 2 hours since installing the board. The upper registers seem somewhat more strident now. I'm wondering if this might be due to a) not enough break-in time on the new board (I kind of doubt this but I'm open to opinions), or b)the fact that the heater voltages on the 12AX7s went from the Dyna-designed 11V to the 12.6V a 12AX7 would normally see. I'm assuming that this is due to the fact that the voltage drop across the rectifier diodes is less than that across the old selenium.
I might want to drop this voltage back down to the original 11V. If I decide to do this, how do I calculate the value of the dropping resistor. I'm sure this is a simple ohm's law calculation but I don't know how to do it. I need to know the required resistance as well as the appropriate wattage rating of the resistor. How do I go about doing this calculation? It seems to me I only know my target voltage but I don't know R (that's what I should be solving for) and I don't know I (I don't think I know it anyway :scratch2: ).
Thanks!
Joe
Thanks!
Joe
