knockbill
Lunatic Member
I searched this, and the common answer is "you don't need to" so that's no help! I assume I need to use a tone signal, not sure what frequency, so it isn't constantly changing...
I have a Ballentine AC volt meter which should measure very small ranges,, DMMs have larger AC ranges, at least the ones I have!!!...
I'm looking to see primarily, what the V out is of these 50C clones... But then I realized, I have a SS phono preamp that will cause certain tube amps to oscillate(motorboat )... If the level pots are low enough, it can work OK, but not at a volume level I want...
May be a stupid question,, but most commercially made amps/preamps list the input output Voltage levels, so it must be relevant... How does one know the output V of scratch built amp/preamp without measuring it tho?
Thanks...
Thanks...
