So I wrote to the source, and got this in reply:
So on my way home from work I picked up a 4 pack of Energizer Lithium AAs and they're working fine. While digging in my battery box I found that I had four Duracell alkalines in there that I had forgotten about. Why I bothered to keep them I don't know. Must have come with something I bought and I just kept them in case I gave something away with a remote or something like that. Two had an expiration date of 2024. I say had, because one of them was leaking into its little plastic case already. This right here is why I never use the bastards, and why I say that alkalines are trash.
I also checked the fuse to which he was referring, but I expected it to be OK because I'm pretty sure I replaced it (what is it with good meters always having the wrong value fuses in them when you get them used?) and it measured at 0.1-0.2 ohms on a cheap Greenlee meter. (couldn't use the Simpson as that is the fuse that protects the resistance measurement circuit.)
You’re correct with the NiMH batteries lowering the voltage enough to cause the problem. I’m guessing that the three ‘AA’ cells are in parallel for replacing the ‘D’ cell. The lithium batteries run at the 1.5 volt level and would work better. Just a note, lithium batteries will hold their voltage until at the end and will suddenly drop. Normally there is very little warning that the battery is going to fail so you may want to keep that in mind and have spares or a ‘D’ cell handy.
Another item I want to mention is that if the unit has had an overload at some time you may want to check the larger 2 Amp Buss fuse by bypassing, jumping, it to test for internal resistance. We have encountered the fuse picking up resistance from being hit by an overload and it will add resistance into the Ohms and mA circuits causing incorrect readings. I hope this information helps. Have a good day.
