Single-Ended KT150 Monoblocs?
They brag about a tertiary winding in the transformer (typically used to provide feedback) then 2 points later claim to have little to no feedback.
They claim .5% distortion at an arbitrary 8w output. 8 watts is less than 1/3 of full rated power. What's the distortion at 28 watts?
I'd speculate its greater than 10%
They look neat, and if you like em, get some.
The bs/lies they tell are about standard for the industry.
More than 30 watts?
Doubtful you would want them to.
I listen to one, almost every day.
It is a beautiful sounding amp.
I'd be concerned about how close that KT150 is to the transformers/choke. You want at least the diameter of the bottle distance from anything for cooling IMHO. Then they show the pair of them with the tubes right next to each other? The integrated amp they sell looks to have at least some distance for cooling.
Power 20watts
Frequency response 7Hz-22kHz
Noise -113dB
Distortion 0.2%
Sensitivity 800mV
Damping factor 0.8
Measurements from some UK hi-fi rag.
Really low DF means it will be quite susceptible to change of character with speaker impedance swings. Might be good, might not be, based on preferences.
I think there was a setting to change the input sensitivity but sounded like it was largely done through feedback, so DF is probably a little higher in that case. I didn't notice measurements though.
Here's the TungSol data for the KT150. This is pentode mode with screen grid at 225V. The salient point is 14% distortion at 20W! This is exactly what one would expect with a single ended pentode. Pentodes make outstanding output tubes in PUSH PULL where the H2 distortion is cancelled in the output transformer, but poor single ended output tubes. That's why single ended is more commonly composed of TRIODE output tubes.
Good points Palustris! Are the manufacturer's specs out of line with reality? SRB02 still loves the sound.
The Icon monoblocs are 18 wpc in triode. Good enough for the Klipsch Forte IIIs but I'd want more than that to cover my speaker collection.
BTW, when I settle on a topology, I'll have my local Indian tech in Dubai give me a quote to build a pair. He was butthurt when I told him I bought a ChiFi KT88 amp.
If you have a standing offer from a tech to build you a tube amp, first of all find out how much cash they need today and wire it to them.
Then ask yourself why you cheaped out and bought junk, instead of hiring your friend, to do what he does professionally.
Then you told him...
That seems rude...
Maybe try asking him, if he would still consider building you an amplifier, then let him. Dont come to us for opinions on what to tell him to do, hes the builder, the artist.
I'm one of those people who will build amplifiers for those who ask and who I deem worthy, a truly skilled craftsman. If you have the opportunity to buy a work of art from a skilled craftsman, but you buy a run of the mill department store quality amp, I dont think you understand what a privilege it is to be able to commission an amplifier, and recieve it with your name engraved in the back.
You seem to not have a clue what you want.
Since you know a friend in the biz, I recommend calling him, and listening to his recommendations. He can demystify topologies, impedance matching, transformers, distortion profiles, power bandwidth, and maybe even teach you how to read a data sheet. Once you two decide on a path forward, find out what he needs to get started and pay him.
The folks who can do this work are dying from the face of the earth. Transformer vendors closing left and right. If you want their work, now is the time to bust out that cash and pay up. In a decade most of the builders won't be with us any more. The industries which fed us will remain shuttered forever.
I have yet to really like how a single ended or PP pentode amp running in triode mode sounds. Maybe because I am comparing them to a 300B SET?
But the little 5wpc single ended pentode amp I built wired UL sounds really good to me. Even with 5% distortion and 40hz-18khz response.
