If the stock cap is rated at 500v I'd stick with that. Also, I tend to shy away from brands I've never heard of - especially some Chinese special from eBay. I'd suggest you use a well known brand (Nichicon, Panasonic, Cornell-Dublier for example) and buy from a major electronics distributor. I use Digi-Key mostly because, as I explained in an earlier post, you can get free shipping under certain conditions.Would the one in pic work?
Any examples of what caps I would use if I wanted to restuff original can?
Sure, that's the idea. The black caps in this pic are snap on Panasonics with their short tabs soldered to the terminal strip, which is hard to see. They do end up quite close to the strip but it works fine. The light blue caps are Xicon radials mounted to terminal strips. They have longer leads, like the ones in the photo you posted, which makes mounting a bit easier. If you're mounting 2 or more snap ons on the same strip you'll need to leave a blank tab between them to allow space for the bodies of the cap or you can mount them on opposite sides of the strip and use the shared tab as ground for the negative sides. You seem to already have holes in your chassis so it would be easy to attach a terminal strip without having to drill anything. Again, go back and find my post about free shipping from Digi-Key. A small parts order gets a lot more expensive when shipping is figured in.Any pics of examples of mounting terminal strip and using snap on caps? Something like this?
