nj pheonix
Lunatic Member
With the help of the forum i snatched victory out of the jaws of defeat on my 6065 which i'm listening to now. I'll have to revisit for lamps but otherwise its done. So , as i alluded to (to crickets) in the last thread, I'm aping Leestereos 6060 update / improvement on a STR 6060.
Things so far are going smoothly. I opted to replace the carbon comp resistors on the amp boards (except for 3) to get at them would require substantial disassembly which i can't justify. They do check in spec.
Just for the record, i'd say about half weren't in spec.
So, before i start reassembling these, I noticed one channel has the original 2SD88 outputs. The other has RCA 3438 outputs (SK is written in another place) so obviously they've been replaced. Here's the question
It was working fine before i started. Should i just leave them be?
Here are alternatives on hand.
I have another pair of 2SD88s (they came for the other, the lesser matched pair).
I have a pair of TX 183s
I also have a new quad of MJ5003Gs
Or is there a better way to go?
I was sort of leaning (barring a more seasoned voice chiming in) clean, new thermal compound and leave.
What do you think?
What do you think?
) , so really it's just a few relatively inexpensive parts.
