Hello all.
I have a Skytec 15" and 1" Active PA Speaker, 1500w Advertised Peak Power.
Ive noticed that at a high volume the woofer (mainly) makes a crackle sound like a loose cable or something alike, I run this speaker with the level on maximum and the power at about 1/2 - 2/3, inbetween those two is where the crackle occurs, so far I havent taken the driver out and the amplifier unit as well to inspect.
I can't see any obvious fault or corrosion on any of the variable resistors (Volume and level control) And I haven't found any loose cables, I have replaced the cables that run to the low woofer with cables with a thicker insulation and still having the same issues.
The only other lead I have is when I push on the cone It has a slightly rough feel to it, but when I push on the dust cap/cover in the center of the driver (providing equal pressure all around the cone) it doesn't have the same rough feel and moves freely.
Any ideas on where to go next would be awesome as Skytec have next to no online help with repairing these units.
Thanks in advance.
Thanks in advance.
