zombiemodern
Hi AK,
Was wondering if anyone here could help with an SL-1200mk1 that's seeing speed irregularity, particularly on power cycles. This is now a DIY project — a third turntable I don't really need but due to the rarity I'd love for it to operate properly. I've taken this to a local tech figuring it was beyond me, but he only swapped the zener diode and charged me $200 which to me was a total ripoff so we parted ways. According to the service manual, the issue is likely that I'm not seeing 20v at the collector of TR-14. Currently I'm seeing a range of negative voltage from -17 – -24v. Unit still measured the same as the collector after trip to the tech.
So far I've:
-Cleaned all pots and switches, oiled the bearing
-Checked the solder connections at the speed switches, refreshed some
-Checked power supply with DMM
-Replaced all electrolytic caps slowly and carefully with new caps from Newark (Nichon, Panny, etc, decent stuff). Axial looked swollen, none were replaced by tech.
-Swapped in a third zener diode from Newark
All this, and no change in the reading I'm getting at TR-14. It looks like speed is slightly more stable but that could be confirmation bias at this point. Does anyone know what this issue could be??
Couple of thoughts:
- I'm measuring wrong or something is wrong with my cheap DMM. Currently I'm using the DC Volt setting w/ sensitivity of 200v, red lead on the collector of TR-14, black lead on Pin 7 for ground. DC batteries test fine.
-Something is wrong with a transistor in the voltage regulation circuit.
Honestly at this point I'm at a total loss of what could be wrong. I'd hate to have to get a new board as I've already sunk too much into this with the useless trip to the tech. I'm just a hobbyist with cheap gear so any and all help from more experienced members is appreciated. Recapped board shot attached.
So far I've:
Couple of thoughts:
