Hi all,
I got a question about Technics SL-1200 MK7 tonearm height (VTA).
I think there is an error in the manual of the MK7.
For example, for a cartridge of 18 mm, the manual says that the tonearm position is 1. It is the same value in the manual of SL-1200G an SL-1200GR.
But the SL-1200MK7 is supplied with a 1,8 / 2 mm little felt mat. The SL-1200G an SL-1200GR are supplied with solid 3 mm rubber mat.
How it can be the same value for these two type of turntable ? I know that the tonearm height for Technics is calculated in termes of supplied mat thickness and stock headshell.
What did you say about that ? I tend to think that the correct tonearm position for 18 mm cartridge on MK7 is more 0 position.
Thanks for your answers !
Best regards,
Arthur
Best regards,
Arthur
