Sansui Louie
Curmudgeon
First, I'll cut to the chase. How do you set the arm height (VTA) on a Technics of the SL-1X00/01 vintage?
And now, for the rest of the story
My old friend, the Technics SL-1401 has found it's way to me. Nuff said on that. Now, on to the FUN!
I've been playing with it since Saturday, and it's funny how time can alter one's memory. Oh, I'm very pleased with the table, but I seem to remember it being *larger*. It's plenty heavy, however. I also seem to remember the tonearm being more complex than it really is. And I don't remember the suspension system at all. I had assumed that it was like my Pioneers...hefty, heavy, all isolation coming from the feet. Curiously, the platter and tonearm are independently sprung from the plinth. Were all the early SL-1X00 and SL-1X01's like this?
The biggest question I have is how does one adjust the VTA? With the Stanton 600EE that came with it (the stylus appears good, I had a peek at it under a microscope), it looked a lot like a 17 year old's Camaro of the same period...jacked up in the back, riding low in the front. I added another rubber mat and a felt one, and that brought the arm up to level, and improved things quite a bit.
I also adjusted the overhang/alignment using the mirrored tool and the freebie from Enjoythemusic. Seems to me that someone said that Technics arms were a little different...not having one for many years, I don't remember. In order to get the adjustment on with the mirrored tool / E.T.M. protractor, it rides almost all the way to the rear of the headshell's travel. Sounds good, though.
The quartz lock on this thing is amazing. Those dots waver nary a bit. Rock steady, dead on...just as I remember.
The torque of the motor and the quartz lock together are impressive. I can drag the label with my thumb with quite an insane amount of pressure before the quartz lock fails and the speed slows down.
How does it compare to my PL-570? Well, it's much less susceptible to feedback - the isolation is better. The speed seems slightly more steady...I can see the 570 vary ever so slightly....negligible, but one can see it. Maybe because those big block-markings on the Pioneer make it more noticeable than the tiny dots on the Technics. The Technics has a wee bit more torque...not that the Pioneer is failing at all in that regard, just the Technics seems to have a little more.
Overall, I think I'll have two turntables on my main system for a while. The Technics/Stanton combo seems to handle noisier records better than the Pioneer/AT440ML combo does, though I don't know why. And both are fun to play with.
Also, if anyone has a dust cover for a SL-1X00/01 series table, I need one.
- Louie
- Louie
