SL-Q3, swap strobe/pilot
Raphaz
AK Subscriber
Trying to swap out the strobe light (or whatever it's called – the visual speed-control light under the glassy pyramid) on the Technics SL-Q3. See picture.
How do I do that, and how difficult is it (with no experience)?
Is it an LED? What products would work?
Where to order?
Thanks for advice!
picture hosting
Where to order?
Thanks for advice!
Check service manual for part number.
https://www.vinylengine.com/library/technics/sl-q3.shtml
Should be a relatively easy task for the knowledgeable turn table restorer.
Maybe too much for a novice/first time user. :idea:
Check KAB for part.
https://www.kabusa.com/frameset.htm?/accesss.htm
If I got that right it's and LED:
SVDEBR5505S (panasonic)
What's the best place to order something like this?
Now comes the tricky part: I want it in green or blue.
As for replacing, I guess I have to open the table and see how hard it is to get to it, and find out if I can replace it myself. May need some help from a friend with clean soldering (if needed).
Thank you, Balifly!
I opened the table. Kinda hard to get to the LED, would have to remove the board and some of the mechanics. See pictures.
Maybe not a job for a novice – unless someone can give me step by step directions (plus, given theres no tricky soldering involved).
Anyone?
Supposedly Panasonic doesn't cary these particular LED bulbs anymore. So far I couldn't find a substitute anywhere on the interweb.
There must be LEDs with similar specs (Volts, connectivity/socket) I could use, no? What exactly should I look for?
Thanks!
What would be a good substitute for the Panasonic SVDEBR5505S LED?
Anybody can guide me through the replacement (step bu step)?
See previous post #4.
Thanks!
