JoshThorne
Last year a got a partially functioning z565 Zenith Moderne turntable.
I immediately ordered a new idler wheel, needle and cartridge. I Cleaned and lubed the changer, and tone-arm mechanisms, and disassembled cleaned and lubed the motor.
For gears I used a synthetic grease, for the motor I used a light synthetic oil. (later I replaced all the resistors and capacitors, except the motor caps)
Everything worked perfectly for 5-6 months, then it started slowing down (or I just noticed that it was slow).
I took apart the motor and re-lubed using grease rather than oil. It was a bit better, then got worse again.
Today I took it apart and found the the new idler wheel was being ground into dust and had dropped rubber dust into the motor. I cleaned it thoroughly with q-tips and alcohol and lubed again. This time, with simple petroleum jelly on the recommendation of a forum poster.
I got it all back together, let it run for an hour, then timed it. It's still running at 29-30 rpms.
Does anyone have any thoughts, or experience with a problem like this?
