gd420
Ok so I have a set of SM-122's (hold the comments I have read em!) but anyways I have searched the forums and have not really found the answer(s) I am looking for. So for the first I have read that OC Speaker repair's kits are just slightly too big and need to be cut. Does any one know of a supplier that has the correct foams? And Number two it seems the original foam was a real foam type of stuff and most of the surrounds available today are rubber or similar (Supposedly to last longer) but I would think that using a stiffer type of surround would change the levels of the woofer? For example a stiffer type of surround would need more power for the same SPL. Am I off base with that or are they so close in stiffness that it does not really matter much? Thanks for the input.
