Small tube amp identification please
kenpoguy
I just picked up this amp, which is delivering only a whisper of a sound. I would like to have it fixed and run a nice little mono system with a single horn loaded speaker from a kit. The info I was able to find on line is that it is a Grommes amp made for Radioshack when the company first started. I have also noticed that the transformer is standing upright instead of laying flat like it should be according to the few pictures I have seen on the net.
Anyway, I think this and hope this is an intergrated amp with a built in phono preamp. and I am hoping it is not a preamp. I would appreciate help identifying what kind of amp it is. I have included 3 pictures. image0.jpeg image1.jpeg image2.jpeg Thank you.
It looks to be a mono integrated. I assume the output transformer is inside the chassis. Probably 12 watts or so output based on the tubes.
It is an integrated amp. Two 6V6GT tubes are good for about 10-12 watts.
Let's see underneath.
If there is a square hole cut in the chassis then the power transformer is probably not original, but if it has one or two holes for the wires, then it is most likely original.
It looks like it has the capability for a mag phono as indicated by the switch on the back.
Little sound could be an open resistor. The can capacitor should also be replaced.
These things are very simple. What is your level of expertise?
I had the same amp. But it was just branded "HiFi". These little amps came with various brands stamped on them. It was a nice little amp. I used it with an old Eico mono tuner. I used it in my shop for several years.
Looks like a Grommes LJ (Little Jewel),, LJ5 has a stand up PT,,, LJ6 has a flat PT... Lots of pics and schematics around... I always passed on them at hamfests,,,, but I think a pair on them would be a cool little mono block system...
Yep,,,they came out in the early 50s,,, quite a few models,,, lots of copies out there also,,, I pictured it as a cool little Fender Champ or Deluxe or so chassis,,,
I was going to use mine for a guitar amp when it stopped working. I thought it was just the rectifier. But the power transformer was shorted out. I sent the OPT to someone. Maybe you?
Not me,, IIRC you sent me a Webcor OPT to match one I had!!! I think I'll grab a LJ next time,,, if ever!!! I get to another show,,,, I think teh chassis would work in a git amp box also...
The phono setting is likely a ceramic phono input. A modern cartridge would not likely have enough output to drive it
Jack and switch shows "MAG" plus it has a mic input so it surely will work with a magnetic cartridge. That is what the 6SC7 is for.
EDIT: Sorry, I replied before I read your later comment. No disrespect! :D
Thank you all for your help! cademan, I have never fixed electronics myself, but always wanted to learn. Maybe I should because I love to collect vintage gear. It's just difficult to find out how to start.
I am confident that I can do a speaker build from a kit, without crossover which is what I am planning to do for this amp. I found a single horn loaded design that looks like fun and I think it would match up well. in the mean time I will have that amp fixed and try to connect it to a single bozak coaxial speaker I have in a large sealed enclosure and see how that sounds.
Thanks again everyone. This is my first post and I am loving this forum already!
Interesting about Radio Shack - I had a pair of MC-1000 which were made by Harmon Kardon ("Thunderous Bass Response") ... of course I took the bait
Cool! It's a Grommes LJ-2, rebranded as Reaist. This is the first piece of equipment Radio Shack sold under their name. The second is a rebranded Harman Kardon FM tuner (before HK started selling under their own name). Interestingly, RS only sold these as Realist for less than a year, when they were sued by the Realist Camera company. This is all in the link posted by Dswanky.
I have two of these, but I think the second is a Realistic with a replacement Realist faceplate. I also have the matching Realist tuner.
I am running mine with an Electro Voice Aristocrat. It makes for a nice mono system. I plan on converting my EV from full range to a two or three way once I get my workshop up and running.
I have found that after repair, it takes about 30 minutes to warm up and start to sound good.
Nice find. I would love to now how much it costs, but I think $$ talk is verboten in this sub-forum.
I picked it up for a song off a guy that was cleaning out a barn. He told me that he must have thrown away at least six " tubed amp things " that day and his buddy said maybe he should save one and see if anybody wanted to buy such a thing! I can only imagine what was lost.
