Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Hi there.
As you can see on the video, the back of the tonearm rotates freely.
In that way he can't hold a weight.
What to do?
(A piece of paper is just for demonstration. For better look at problem.) Thanx for any help.
Hi there.
What to do?
yes, use a droplet of crazy glue on both rubber couplers and slide the armtube stub over it. That's how a coupler swap is done on SME's. Be careful with the glue! Just a tiny droplet that won't drip all over.
The grommet must be glued by cyanoacrilate. I replaced it in my SME 3009 because it went rotten and the sub weight fell down over the top of the plinth. The replacement kit included the glue together with the new grommet.
Hi there.
What to do?
Hi, you need to put glue in the grommet. I bought it in Home Depot (see the photos) and you will resolve your problem.[/QUOT
Ok, I did not realize that you are in Croatia. You need to find a glue that contains Cyanoacrylate for a better result. Good luck.
