Imagine you are sleeping sound, dreaming of tubes and wires (Miss Sacremento, you’re BEAUTIFUL!) and out of nowhere at a little after four, the heart-pounding, shrilly-screeching BEEP – BEEP – BEEP – BEEP – BEEP!!!
What the… was I dreaming? Screechy-shrilling BEEP – BEEP – BEEP – BEEP – BEEP!!!
Suddenly, I realize “SMOKE ALARMS!!!!”
I run to the bedroom door, feel it for heat (thanks 3rd grade!)… Nothing! Open the door, frantically running through the house. No smoke, no bright dancing lights indicating fire anywhere. Check the garage, the basement, absolutely nothing! I pulled TWO smoke alarms down and removed the batteries and stayed up the rest of the morning, and absolutely nothing. Not even a hint. Chalked it up to another one of those strange universal occurrences in my life, changed the batteries and put them back up the following night.
BEEP – BEEP – BEEP – BEEP – BEEP, not at four, this time quarter after three. Again, no fire, no smoke. Frustrated, I just removed the batteries and went back to bed resolving to buy new detectors.
Forgot about it (oops) and remembered about a week later so I decided to put the old ones back up instead. Both bad? Not likely, but I guess possible. Two weeks went by without incident, but then of course, it started again.
I want to run this by you guys so you can see if the following theory (the only theory I have) fits, and if not, give me yours. If my theory is right, buying new ones won’t help, but if you agree with me, then I can at least address that issue and sleep better. If your theory is right, you have my indebted gratitude because I am afraid this crying-wolf thing is going to burn me in the end (I don't even check the door anymore. They didn't cover that in third grade!) Even if I go and buy new detectors, I really won’t believe that was the problem (since the old ones went without error for those two weeks and I'm pretty sure they would be fine tonight.) Knowing why is the peace of mind I am looking for. :yes:
My theory: I have an electronic, programmable thermostat to save energy (or offset my audio draw
) and it is set to 62 at night. We have had brutally cold, windy nights, at or below 0 with wind chills to -30. Could the smoke detectors be getting really cold while the house is cooling down and then when the heat kicks on (when it gets below 62) the sudden rise in temperature tricks the detectors into thinking there is a fire? Two detectors are affected, they are the same make and model, independently powered and in the same relative area (within 50’ of each other.) I have baseboard, boiler heat (not steam) but the smoke detectors are not directly above any of the runs. The smoke detectors are about 6 feet from a hallway entrance, which does have a baseboard along it part of the way in the hall. I have lived here, in this house, with these detectors for over 7 years (thermostats about 4 years) without incident before, but this winter has been unseasonably chilly here. What do you think? Anyone? :scratch2:
Spideehead69 is absolutely right... How is your house heated? Gas/Propane? Are you sure your you don't have a carbon monoxide problem??????!!!!!!!!! Many smoke detectors also sound the alarm for carbon monoxide. Are you or your family members waking up with a headache in the morning? Tired all day? Please look into that!
