Ethan Pierce
Hello,
I was doing a simple recap of my beloved sx-770, everything was going well until I got to the main amp board. Just to reiterate, all the other boards were recapped and tested functional. When I replaced the caps on the main amp the left channel had no signal so started trouble shooting and seemingly made things worse. There was smoke coming from the driver transistor 2SC904. So I ordered all new transistors just for fun, I replaced them all on the left channel and now the white 0.5 ohm 2w resistors are burning up and there is a LOT of smoke.
Here's the transistors I used as replacements: KSA1220AYS, KSC1815YTA, KSC1815FTA, KSC2960AYS, TIP41A.
Anyone have any ideas? Also, where to get replacement wire wound 0.5ohm 2w resistors. Thank you!
