Picked up a cool Kenwood Model Nine GX at our recent New England get together a few weeks back that I'm restoring.
The ugliest problem it had was that the lever on the power switch was snapped off flush with the front panel.
After looking around for a replacement I decided that it was fix it time/
Essentially I took a similar lever from a Pioneer switch I had and attached it. Here's how:
1 - Drill 2 small holes in the new lever - I used a #61 drill bit.
2 - Drill 2 matching holes in the old switch lever.
3 - Sand the 2 mating surfaces to remove the coating and clean with some alcohol.
4 - Spread a dab of the ever popular JB weld epoxy on one surface.
5 - Connect the 2 levers with some stainless steel safety wire, bend flush.
6 - Clamp together with some vise grips and allow to harden.
7 - Trim the wire and put a but of heat shrink tubing over it all.
I had to trim the switch mounting slot to allow for the thicker lever.
Another save - now on to the recapping and LED lighting, to be addressed in the Kenwood Forum.
Before
After
Before
After
